I am about to get a Nucleus. I am currently using my PC as a core during the trial period. When Nucleus arrives do I need to delete previous core and all associated files or just set up Nucleus?
I am new to this and wonder is this post private to support only?
This should give you a good start: https://help.roonlabs.com/portal/en/kb/articles/migration
Thank you for the reply. Just want to get it right the first time.
Are all help post public? Is there a way to ask a question directly to support?
Help on the forums is public facing. You can email them directly from Roon’s website.
Hi @Sam_Presley,
The migration article shared above is definitely the way to go! If you have any questions about the process please feel free to ask.
You can fill out our contact form here if you’d prefer, though as you can see we have an awesome community here that can be extremely helpful as well!
