432 Evo Standard fedora build 884
Roon remote build 880 Ipad 15.2
Melco S100
Gold note IS-1000
3,000 tracks
tried to assemble under the same roof an album with 2 CDs. was able to merge but the CD2 was taken as CD1 and then the tracks are not in the good order and the album picture is lost.
is there a way after the fact to correct track and picture issue ?
if not can I undo the merge and then try to reassemble the album ?
when assembling the album from 2 CDs how can I reorder the album (was not able to find the … icon described in the documentation)
Don’t know if this helps, but if it’s a local copy of the CD, I make a folder, and then one subfolder for each CD under that. I put the tracks for a particular CD in the subfolder for that CD. Roon seems to get the hint just fine. For instance,
Roy_Hargrove__Mulgrew_Miller__In_Harmony/
Disk 1/
01 What is this thing called love?.flac
02 ...
Disk 2/
01 Never let me go.flac
02 ...
I had just this problem with a recent rip of a 2 disc set into my Nucleus.
I followed the help system advice and the detailed solution shown by Bill worked best for me.
It feels like an orphan from 2002 UI/UX, but once you figure it out it works. I try to resolve 90+% of my issues using tags (at least for local files), so that if I ever have to redo my library it will be zero effort, but there is a tail I’ve had to do with “fix grouping”, and yes it works great.
I often use the grouping feature to “fix” Tidal releases to breakup remastered releases into the individual albums. I hate it when they combine many albums into one release so you can’t tell what the original albums names are. It’s a pain then to have to go edit the album artwork as well. I like that Roon let’s us edit some of this data for Tidal stuff.
