Hi Guys, I just recently got a sonore optical rendu module. Here is my connection:
Router -> Uptone etherregen -> Optical module using ethernet cable -> Fibernetwork cable to Optical Rendu -> USB to DAC.
My music server (Euphony OS) is also connected to the ether regen.
If I go to www.sonicorbiter.com, my optical rendu is not being discovered. Any thoughts?
The opticalModule is gigabit only, which side of the etherRegen is it connected to?
Do you have a green LED on the opticalModule?
Orange means no internet connection ( no gigabit speed connection possibly )
Do you have a gigabit switch you could swap for the etherRegen and see if the oR works?
Turned out, the connection was bad. I re-did it and it worked., Thanks!
