hi just bought a new denon 4500 avr is it possible to get audio from my nuc hdmi to a hdmi on the denon?
i get sound from the airplay but not through hdmi.
i have the following options in roon settings which are a bit confusing for me
hda intel pch alc283 analogue
hda intel hdmi 0
hda intel hdmi 1
hda intel hdmi 2
hda intel hdmi 3
hda intel hdmi 4
do i need to initiate the hdmi port on the nuc if so how do i do this?
Thanks. From your Control can you navigate to Settings > Audio and share a screenshot of the section “Connected to Core”? Each entry, as set out in your original post, should be Enabled by clinking the blue button and providing a device name.
No, just the first hdmi 0 channel needs to be enabled and given a name. Here’s an example taken from my NUC running ROCK, which is connected to a Denon 3808…
hi thank you for the screenshot
my bad my input was still on analogue and not hdmi on the denon amp got sound now.
another question can i get dsd through the hdmi what do i need to change in roon audio settings?
And here’s what I have in the device settings. This is for my Denon 3808, so it might be different for the newer 4500 model. Note that I set the max sample rate to 96 kHz, and explicitly set for 7.1 channels (even though my source material will be stereo or 5.1)
