Yes, sure, I will do whatever checks I can.
So… can you remove the Sennheiser bluetooth dongle?
And also show me the output for the following command:
systemctl status inputlirc
I removed the Sennheiser dongle and restarted the Raspberry Pi.
Now, the Previous and Next buttons on the remote are working but nothing else.
I sent feedback: f47c54954c668215
* inputlirc.service - Zeroconf LIRC daemon using input event devices
Loaded: loaded (/usr/lib/systemd/system/inputlirc.service; enabled; vendor p>
Active: active (running) since Thu 2018-07-05 20:46:43 BST; 9 months 11 days>
Docs: man:inputlircd(8)
Main PID: 274 (inputlircd)
Tasks: 1 (limit: 1763)
CGroup: /system.slice/inputlirc.service
`-274 /usr/sbin/inputlircd -f -m 0 -n *HBGIC*
Jul 05 20:46:43 ropieee systemd[1]: Started Zeroconf LIRC daemon using input ev>
Jul 05 20:46:43 ropieee inputlircd[274]: /dev/input/event1 1f
Jul 05 20:46:43 ropieee inputlircd[274]: /dev/input/event0 120013
Jul 05 20:46:43 ropieee inputlircd[274]: Started
Jul 05 20:46:43 ropieee inputlircd[274]: inputlircd: Started
Ok. That’s what I thought.
This means that it is working for those things supported by RoPieee: play/pause and prev/next.
What more are you expecting to work?
Volume would be good.
And working with the Sennheiser too, which I use to listen to the headphones.
Volume is on the roadmap, but no idea when that’s actually going to be implemented.
the Sennheiser is not something that I’m interested (for now) in implementing, sorry.
Regards,
Harry,
can you put a volume control on the screen too?
