MacBook Pro OSX 12.0.1
about 6000 all from Tidal
Roon won’t launch. It jumps once in my dock and stops.
Can you confirm which version of Roon you downloaded?
Just to make sure you download one that has the control app and not just the server or bridge.
Not sure how to answer “not just the server or bridge” other than I’ve been running Roon on the same Mac for years without this issue so I had what I needed to run Roon, this is not a new install. The version of Roon, I’m not sure. I don’t know how to check without starting Roon. I believe it was up to date with in last few weeks.
Ah, ok, I read it as you were just starting with Roon and couldn’t get it running.
Try this thread? May not be exactly your issue but there are some good suggestion in the thread:
Or you can wait for the support guys to respond…
