Windows 10 on laptop. I5-2410 cpu@2.30 ghz. Ram 6gb. Roon version 1.7 build 667 stable 64 bit
Asus router Rt-Ax92u. 2 of them. Ai Mesh system.
Jbl link music. Jbl link 300. Both have chromecast. Wi fi only.
I have one Lumin d2 hardwired in my main zone. I have node 2i in second zone hardwired. I just installed the roon system a few days ago.
Before roon I was able to stream to the two Jbl units via wifi, through chromecast with no issues. I do the speed test upstairs where the jbl units are and get 110 mbps.
Only have issues such as the audio doesn’t start when trying to use through roon.
The router has three bands. The jbl units are on the 5.2 band. Along with this tablet, its the only thing on that band.
Yes the two end points work perfect. (Lumin and bluesound hardwired)
And for both the Jbl link music and Jbl link 300, both tidal and my local music which is on a Wd my book don’t play through roon. And in contrast in the native tidal ap, ican send audio to them no problem as well as through the native deezer app.
(I forget to mention in first post that my local music is stored on a western digital mybook live, which is hardwired to router)
When you say you are having the issue streaming to the Chromecasts, does it work at all?
Or does Roon show an error each time you try to play something?
Can you share the error message you are getting?
O wow, my 4 year old was messing around with my tablet and I started asking hearing music from one of my chromecast jbl speakers! He was just taping the play pause button and it would start.
So I select a song and hit play and nothing happens. No music. But I can control the volume steps. If I hit the pause then play button, then the music starts. This seems to work every time. When I skip tracks, I have to repeat the process.
Oh and this works for my local music and tidal account.
Its definitely weird as I can stream from the native deezer and tidal app to the chromecast devices and it works fine.
I just checked to see what would happen if I let the song finish. If another song would need to have the play pause button and yes it does.
Hi, ok just checked and its the same. Play pause to get it going and again for the next song. And local music is the same as tidal. And I put the tablet to 2.4 and thru the native deezer and tidal app am able to stream no problems.
I did only see this option (power of 2) on some of my CCA. Reset settings to default and it will appear. Max pcm rate worked great aswell. With linear phase filter as i picked it sounded a little less harsch. Just a matter of taste and minimum phase gives a softer sound also.
