I am trying to configure my rasperberry pi 4 model b 2019 4gb and I am running into problems with the wifi and official 7" display. I have it connected to a Schiit Modius/Magnius stack. I am using a 2018 MacBook Pro as my server. The only extension showing in Roon is spockfish remote control.
First, the wifi is not working. I have it plugged in via USB to the Modius and it will play music if I am using ethernet. I went into the setting on RoPiee and I activate wifi and entered my password (rebooted too).
Also the display turns on and get to the RoPiee is ready section. It play music, but stays on that screen and does not show the album cover. I have the name of the DAC in Roon and Ropiee name in setting the same (SchiitRopieee).
In the display (ropieee GUI) and audio settings (roon) zone must be identical and case matters.
Also you must in roon settings extensions enable and pair the remote for the ropieee
If there is no display tab shown in ropieee you perhaps have not got it connected or need to start a fresh flash of ropieee on an sd card, and install again.
