When using the HiFi Berry AMP+ with Roon Bridge (1.0 build 34 and Roon 1.2 build 157) i can’t get the hardware volume to work. When selecting “Use Device Controls” it says “Volume control is Fixed”.
Could it be because the AMP+ doesn’t have a hardware mute-option?
We’ve seen a few devices that separate vol/mute controls, but this is the first that has no mute controls at all…I wonder why they did that (and if it was deliberate or accidental).
We’re going to try to get our hands on an AMP+ to play with this. Maybe we can do some faking of mute functionality in cases where it’s not available.
We got our hands on an AMP+. The next release of Roon will support volume control–but not mute–on this device.
If we start running into more of these situations, we might consider doing a soft mute control. If it’s just this one strange driver, then it will probably remain as-is.
I don’t mind mute that much… you slide it down all the way… muted.
But it has a strange logarithmic curve. Still silent at 50, too loud at 75.
Can that be remedied somehow?
The volume scale is determined by the device + driver, unfortunately. As far as I know, what you see in Roon should directly correspond to what you can see in alsamixer. We don’t have any settings for re-writing the volume scale.
On my HiFi Berry AMP+ the volume is working fine (i believe linear) and not at all how you describe it. Both with the Volumio 2 image and a basic Raspbian Jessie Lite installation.
