TiEcs
(Bert Degroef)
November 7, 2020, 5:12pm
21
I can’t get it to upgrade to the beta version.
I reflashed RoPieee XL, all boots well, I change the reboot option to beta, and it says:
*** Welcome to RoPieee! ***
… entering stage 3. We’re operational in a sec …
… waiting for internet connection …
… waiting for NTP syncronisation …
Then it takes quite some time and all shuts off.
When I power it off and on, it starts over and over.
I will now try to reflash my card with regular RoPieee
spockfish
(Harry ten Berge)
November 7, 2020, 5:40pm
22
Don’t do that. You are expecting something from the screen, but the screen is not used in RoPieee.
And after the initial boot stage the screen is turned off.
So no need to reflash. What is not working?
TiEcs
(Bert Degroef)
November 9, 2020, 7:45am
23
Problem solved with the help of Harry.
Restarted my Roon core, and clean install solved my issues.
Thanks Harry.
stevet
November 23, 2020, 10:32pm
24
Hi - can I switch back to the Stable release and pickup this change ?
