Occationaly but not every time, higher bitrate files or DSD files will sound “fuzzy” or distorted. Usually, I can play different files and come back to the distorted files and they sound normal. In the case of DSD files which I know are compatible with the DAC will sound good for a awhile, and then start to have problems. On my second system, where I have a Bifrost 2 which Roon downsamples I don’t have a problem at all.
I’m just curious if it’s possible the Roon Core is not powerful enough or there is something wrong with the DAC.
An example of a album I have trouble with occasionally is Solarium which is 352.8khz-24bit
I can only speculate but I believe what you’re hearing is something, either streamer or DAC, not keeping up with that high of a bitrate. If you’re right on the edge cables may influence speed / stability across the USB. What is your streamer? I assume you are wired and no wifi?
Can you downsample, one step at a time, on the main system and hear if it smooths out? I’d be interested to know if reducing the bitrate solves the issue.
