High Quality sound
Intel Nuc headless
I was getting high quality then it changed to enhanced and do not know what I did any ideas anybody.
Many thanks
The signal path should give an indication why it has changed.
My Cambridge shows up as enhanced since it automatically upsamples everything to 384 kHz.
You’re upsampling which by definition is not bit perfect. However, enhanced does not imply inferior. In fact it may sound better to you. That’s a matter of perspective.
Hi Victor,
to achieve better answers it would be very helpful to fill out the given support template in your first post (you can still edit-in the information).
Also give us a screenshot of your signal path info to gaze at - says more than a thousand words.
Good luck!
This is the hierarchy of sound quality as published by a third party Roon guide.
  • Bright Purple: Lossless – the stream is going from the file to the device without being modified.
  • Shining Blue: Enhanced – Roon is performing some user-selected signal processing on the audio (volume leveling, DSP Engine, etc.)
  • Green: High Quality – OS Mixer outputs, or conversions for compatibility, and DSP volume.
  • Yellow: Low quality – lossy file format playback.
By my reckoning lossless or enhanced are both better than high quality. To better understand what the indications mean look at the Roon knowledge base.
Describe you setup as to what’s connected to what and what method of connection you’re using for Roon to play music to your audio devices . Sounds like you’re either using non exclusive system output of a pc or perhaps Airplay to play music. Both of which will not show as lossless.
