If I listen to an album with 192 kHz / 24 Bit on my Linn Selekt DSM Surround, I need to turn the volume up 25-30% (higher) compared to the same album with 44,1 kHz /16 Bit.
Can I fix that through some settings?
Have a nice WE
Greetings
Torben
Have a nice WE
Greetings
Torben
It could be that the hi-res uses a different master from the redbook. Are they local or streaming files?
You could set Auto Levelling on , spoils Bit Perfect but does work, I keep it on for my headphones it saves on surprises
Are you setting volume control in roon software?
In that case you can try the option fixed volume.
For me it worked well.
