Honor taps when volume control is open
I’ve accepted it, but over time it has become increasingly annoying.
I have volume control open most of the time. When it is open, I can tap to go somewhere and all that happens is the volume control closes. Then I tap again to do what I originally intended. Please let taps pass through when volume control is open.
Actually, it could be in the footer as a slider. The file display doesn’t need to go across the whole page. Just a little bit of real estate at the bottom right you could fit a volume slider there.
