OK, thanks for your advice, I will then keep the Roon Core on my notebook (i7 8gen, 1TB SSD, etc) and try to get a NUC/ROCK instead the notebook.
Johannes
Johannes
You should try it, and see how whether the QNAP can support the playback and what the loading on the device is.
It could be Roon are nervous and set the hardware requirements high, as many of the DSP functions require CPU and RAM and donāt want negative experiences with sluggish hardware.
You can also keep it there, while you are sourcing your NUC.
It could still be better than running from the Laptop (a general purpose device)
So how are you getting on with Roon & the UPnP Bridge to your ND5XS?
Thank you for your question. Everything is fine since I installed that device. Iāve not had any troubles setting up this configuration and it is running since the beginning. In the very near future Iāll move to a Naim NDX2 which is already Roon ready. Iām running the Roon core on a Intel NUC, which is also a very smooth configuration that doesnāt cause any troubles.
kind regards,
Johannes
Ok, very good.
May I throw in, that there a number of 2nd hand NDS units coming up, being sold as people go to the ND555.
Now you have the Roon -> Naim route sorted, the cost of a new NDX2 would fund a 2nd hand NDS instead.
But you would still need a PSU for the NDS - but you could get that now on the ND5XS. I found that adding a XP5XS to the ND5XS made a big difference, and I used that PSU with the NDS for a while.
Just a thought
Thanks for your advice. I currently have the ND5XS running along with a NAIM DAC and a NAIM XP5XS. And Iāve already ordered the NDX2 along with an XPS DR to upgrade my current setup.
Hi all. Iām a complete newbie to Roon. I have a Synology NAS that I have setup as my Roon Core which contains all my ripped CDs as FLAC files on the NAS SSD drives, plus my iTunes library. I was able to set that up easily.
From there I want to run lossless files to my Naim kit (NDX.282.HiCapDR,NAPSC.250.2). I have read on this forum that the best approach is to get a bridge (https://www.smallgreencomputer.com/products/upnpbridge?variant=6964135395362).
My questions.
Thank you and sorry for the long message!
Hi @Simon_Cool and welcome to roon,
There are detailed instructions in the Sonore section here on the Roon fourm but basically you set up your NDX through the sonic orbiter web interface - itās a few click process, and then choose enable squeezebox support in roon and then the roon app sees your NDX. (it is the original NDX not the NDX2?)
I know someone who upgraded from NDS to ND555 so he may have a bridge surplus to requirements so if you PM me I could see if he is interested in selling, presuming youāre in Europe.
.sjb
Or if not, there was one here for sale FS: Sonore UPnP Bridge
I run Roon through my NDS all the time, now with the Sonore UPnP Bridge. No need to touch the Naim App, and get Tidal MQA Masters playback via Roon, as well as better Tidal integration.
Just make sure the Bridge hardware is SonicOrbiter 2.5 or greater, as I had problems with the earlier 2.3 version on the SoSE unit.
At present, I donāt see/feel the need to upgrade to the ND555, but I havenāt heard one yet
Hi, Iāve bought the Sonore UPnP bridge following the advise above to stream Roon to my Naim streamer. But Iām still confused on the best settings on the bridge itself and in Roon to get the best possible audio quality. Could somebody share a screenshot of the settings? Would really appreciate that. Thx!
Sure
On the SonoreUPnP Bridge Settings
Then you just select the Bridge as a Zone, hit play and the Naim Network Player will auto select the UPnP input and receive the stream.
Just remember that the Naim Network Player is no-longer commanding the file to be served to it, as with a UPnP server Architecture, here with Roon it is now being sent to it, i.e. the Naim device is no-longer in control, Hence the terminology āRoon Endpointā.
If there are tracks in the Roon Play Queue, Roon will continue to push these at the Endpoint, until the Queue is empty, irrespective if the input on the Naim Network Player has been set to another input or source. If you need to selection another input on the Naim Network Player ensure that Roon is no-longer serving files, by either clearing the queue or hitting pause before making the source selection.
Someone had issue with the SonoreUPnP Bridge with a Naim 272, which is a Streaming PreAmp, trying to select other sources while there was still tracks in the playback queue where the pushed stream would keep forcing the 272 back to the Roon stream, which they found unworkable.
Hope this helps,
Simon
Thx Simon!
Did that work for you?
Yes, it works. It already did, I was just insecure about the best settings
Hi,
sorry I canāt help you with that issue since I moved from the ND5XS to a NDX2.
regards,
Johannes
