ARC is accessible on my phone and it works great on headphones, either in France where I live or in the hotel in Germany where I recently traveled. Great!
I also installed it on an iPad, I have access to all my music description on the screen, but no sound comes out while this iPad is connected in Airplay to a Mu-So 1st generation. Shall I use a specific cable to connect the iPad to the Mu-So, or use an other way to connect : settings in the iPad, or… ?
Have you tried pairing the Mu-So with the iPad using Bluetooth? If you do that, ARC should stream directly to the Mu-So (this method works with my Bluesound Node.)
Thanks Martin. The iPad is paired with the Mu-so but it doesn’t connect via Bluetooth. Bluetooth on iPad identifies the Mu-So, I ask to connect, but it is not stable and the link is quickly cut.
Maybe it is because the iPad is already connected via Airplay or Wifi to streams radios. A kind of conflict ?
Bluetooth should be stable, but try turning off (closing other apps using Airplay etc.) I don’t have the Mu-So, but can stream ARC to a Node via Bluetooth.
If you have the Mu-So V2, there’s Chromecast, which Roon supports.
Thanks. The Mu-So is first generation. I will try again, but, really, it is not so important to me. I like to discover new musics through the radios and use Roon when I want to do my own choices.
Have a nice day.
