I have tidal and local files.
I just want to have a playlist with a m3u (relative path of the songs) without duplicate my files.
While I have A TONS of playlists, I don’t want loose them.
Any tricks ?
Any tricks ?
Tons of playlists in roon or outside of roon?
Hi Eric,
Local Roon playlists are stored in Roon Database Backups. Local playlists can also be converted to TIDAL by using Soundiiz:
Thx, In fact, export to Excel do the tricks for me.
I can copy the relative path (last excel columns) and copy to text file, rename that file the name of the playlist and give it the extention .m3u.
I can after put it in roon library folder to import.
