MacBook Pro
macOS Monterey (12.5)
3.5 GHz dual-core i7
16GB Memory
Ethernet between MBP running RoonCore and iMac running Roon client
Tested with Cambridge Audio 851N, connected to Core via ethernet (through TP switch)
~60k
While trying to continue debugging this issue:
I noticed the following log entries after a Core restart (and loss of playlists):
09/25 07:38:46 Trace: [storage] [directory] Begin queuing fs events, ignoreitunes: True, ignoreplaylists: True
But I can’t find any setting in Roon that directly correlates to either of these values: ignoreitunes or ignoreplaylists.
What are these settings, what do they actually do, and where can I change them to False for further testing? Google searching and searching the forums only turns up these values when others have shared logs as well, can’t find any actual details about what they do or how to set them.
