Is there any way to improve the also known as - or maybe a merge of artists.
I was listening to some works by Tony Allen and Roon also lists some work under Ladi Tony Alabi. They are the same person so is there anyway I can fix or contribute to to fix it?
Select both artists (in this case the easiest way would be to add something by both to your library if you haven’t already, filter your artists by “Tony” and right click them both) and you can merge them, placing everything under one or other profile. These merges are then listed in your library settings and can be undone if it’s ever necessary.
