I have a Topping DAC which is DSD capable. I can’t find it on the setup screen. I would like to figure out how to find the device so I can disable the DSD to PCM setting.
The Topping DAC is connected to my Mac OS via a USB cable
Macs don’t native support DSD you can send via DoP which is the DSD stream over PCM. Set DSD strategy to the correct method in the device settings and the DAC should then see it correctly.
