Hi there,
I am looking for more detailed instructions on how to setup headphone corrections in matrix using Oratory PEQ text files.
HQP manual is unfortunately not very helpful for me.
On the Matrix pipeline I can load the text file and I can see it in the plot. But how can I activate these filters? Shouldn‘t be the gain column be populated automatically?
Edit: I uploaded another screen shot. One can see that the preamp gain for the HE1000V2 of -2.5 dB is not shown in the plot. For the Dan Clark file (-3.3 dB, same format) it can be seen.
I did save them, then load, so I change them on the fly from apps (desktop or mobile).
I do not remember the gain being populated by default, I did -3 some times -5 just to be safe.
Oh now I get what you say, in the text file there is a preamp gain, I did not have that line but looks like the mirrored maximum gain from the strongest filter.
I think it is shown otherwise the power graph would go above 0.
I’m not that advanced but maybe until better explanations you can play around.
Thanks, I was thinking to complicated.
I thought each headphone had to go into a different channel or they had to show up in the lower section.
Simply press browse in channel 1, than give it a name in upper row and press save. Do this with all head phones and they will also show up in the remote.
Can you please show the structure of a PEQ.txt file?
I would like to use e.g. for my Meze 109 Pro this here, does that fit:
Preamp: -5.4 dB
Filter 1: ON PK Fc 95 Hz Gain -3.1 dB Q 0.50
Filter 2: ON LS Fc 105 Hz Gain 5.5 dB Q 0.71
Filter 3: ON PK Fc 215 Hz Gain -0.7 dB Q 2.00
Filter 4: ON PK Fc 880 Hz Gain -0.9 dB Q 2.00
Filter 5: ON PK Fc 2100 Hz Gain 5.8 dB Q 1.00
Filter 6: ON PK Fc 2850 Hz Gain -2.5 dB Q 4.00
Filter 7: ON PK Fc 3800 Hz Gain -2.0 dB Q 6.00
Filter 8: ON PK Fc 7400 Hz Gain -2.5 dB Q 5.00
Filter 9: ON HS Fc 10000 Hz Gain -3.0 dB Q 0.71
@jussi_laako:
Do you think it could be possible to show in the signal path in Roon which matrix file is active?
In that way one could see directly in Roon which correction is currently active.
This would be very helpful and would dramatically reduce these incidences where I think “Why in hell does my headphone sounds so crappy??? Ah, yes, wrong correction file ”
I’ve seen this on Desktop version a couple times - normally only if I have to force quit HQP for some reason, then any matrix profiles i had just created disappeared on next reopening
