How to identify what's difference between two USB Audio Device Setup
When I connect my Roon by USB on ML No585, the Audio Device is USB2.0 High Speed True HD Audio (generic), but if I change the Device setup searching by Mark Levinson, I can find the specific ML No519 (also USB audio).
So it works fine…
How can I find the difference between both option?
Thank you!
Hello @Edu_Zn ,
Once you identify the USB zone, the specific audio settings related to it will be applied (max sample/bit rate). If you use the generic driver, there may be some options available that won’t work in Roon’s Device Setup menu.
