- macOS 10.15.7
- Roon Core 1.7 (710)
- Ropieee 3.020 on Pi3/Allo Boss Dac
- Unifi network, both mac and Pi connected via wired network
I have a number of Roon endpoints around the house, many of them running Popieee on Raspberry Pi. Two in particular are normally grouped together. This morning one of those 2 Pi’s was reported as unavailable in the Roon group. That happened once before (different endpoint, same group) but it was clear that Ropieee had crashed (couldn’t reach it on the network at all), and rebooting the Pi fixed it immediately.
In this case, everything appears normal with Ropieee - the web interface works as normal, Airplay works etc. Apart from this device being unavailable, everything with Roon in general seems normal. However, after rebooting both the Mac and the Pi (multiple times), Roon still reports that the device is unavailable, and I can’t remove it from the group.
Is there some ‘behind the scenes’ way to remove a missing device from a Roon group?
[update] - I just realised that the endpoint is working fine after all, but Roon started seeing it with a different name from when it was part of the group. So everything is now working, except I now permanently have a missing endpoint as part of this group. How can I remove this now non-existent endpoint from the group?
