Windows 11
Xfinity router wired
Cambridge CXNv2
Over 200,000
Will ARC stream better quality on 5G or WiFi?
Windows 11
Cambridge CXNv2
Over 200,000
No, unless you have some sort of problem with one or the other. Use WIFI at home and cellular when away from WIFI. If you want the best SQ, set Roon ARC to “Original Format” for both WIFI and Cellular and attach a good DAC to your phone and use good headphones. Of course the SQ is no better than the album or track you have in your library or stream from Tidal and/or Qobuz.
Ok. Thanks
