Hi there,
Here is a HowTo turning off the network LEDs behind the raspberry pi. It works with PI 2 and 3.
For PI 3+, the below detailed method will not work. The process has been simplified by adding the following lines to the /boot/config.txt:
dtparam=eth_led0=14
dtparam=eth_led1=14
For Pi 2 & 3:
Download the lan951x-led-ctl program:
SSH access to your RoPieee, username “root” and password “root”.
pacman -S nano
pacman -S libusb-compat
pacman -S make
pacman -S gcc
Create a temporary folder for installation of the program under your /home folder.
Unzip and copy the previously download files in the above created directory.
(I use WinSCP for the above steps).
Back to your SSH consol:
Go to folder /home/lan951x-led-ctl-master
Install the program by running:
make install
Run the program and confirm the LEDs are off:
lan951x-led-ctl --fdx=0 --lnk=0 --spd=0
Create a script to run the program:
mkdir /home/root
cd /home/root
nano networkledoff.sh
Create a service that will be called at boot of RoPieee:
nano /lib/systemd/system/networkledoff.service
[Unit]
Description=Network LED Off Module
[Service]
Type=oneshot
ExecStart=bash /home/root/networkledoff.sh &
[Install]
WantedBy=multi-user.target
Enable the service:
systemctl enable networkledoff.service
Remove the compilation tools for cleaning purposes:
pacman -Rs gcc
pacman -Rs make
pacman -Rs nano
Delete temporary installation files:
Delete folder /home/NetworkLED
@spockfish: Would be great to add this function to the already existing LED option of the Advanced tab.
