Hi all,
What would be the best ethernet cable to connect some computers to a switch, or direct to a streamer for DSD512 and higher?
I know how a shield galvanic connection can ruin the sound, so as Jussi recomanded, I am looking for some cat6a U/UTP.
Dedicated “high end” cables are not UTP
High quality UTP cables are not always cat6a
Between the Blue Jeans, Catsnake, or DIY Beldene, who seems to be the preferred cables, which ones are cat6a U/UTP?
Belden 1303 is not UTP and 1305 is cat5a (what Catsnake uses).
The same with Blue Jeans cables.
So, what cat6a U/UTP cable should I search for my Jcat XE NIC on HQ Player PC.
Thank you
Bogdan
