почему после установки HQPlayerDesktop его перестало слышно
why after installing HQPlayerDesktop it is no longer audible
Please use Google Translate to communicate.
You will need to give us more detail. Was HQPlayer working before an upgrade or is this a new install ? Can you load screenshots of the main and settings windows ?
Пожалуйста, используйте Google Translate для общения.
Вам нужно будет дать нам более подробную информацию. HQPlayer работал до обновления или это новая установка? Можете ли вы загрузить скриншоты главного окна и окна настроек?
Are you getting playback in Roon without HQ Player ? This article contains information about setting up audio devices in Roon.
This article describes how to configure Roon and HQ Player to work with each other. You have to point Roon to HQ Player (using either localhost or an IP address) and select the HQ Player Zone as the output Zone in Roon.
What sort of DAC do you have ? How is it connected to your computer ? Are there any other options in the Device menu ?
This Kick Start guide can be helpful when initially setting up HQ Player.
