Login as “root” and then run “aplay -l” and take note of the card number.
Then run “alsamixer -c 0” where you replace 0 with the applicable card number. Now you can adjust volume if there is such. You can set it to 100% if you don’t want to use hardware volume control.
Then you can store the settings for next boot with “alsactl store”. And now you are done.
