I’ve recently added HQPlayer to my set up (H190+ KEF R3).
While I couldn’t be happier about noticable sound improvement, one thing doesn’t let me go.
Tidal started sound way better than my offline files, stored on Roon Core (mac mini i7 in my case).
I mean, I’ve compared the same versions of the same albums and even songs – and every Tidal’s version sound brighter, a bit louder and has more brightness in the texture, though from a technical standpoint it doesn’t make any sense to me.
Did I do something wrong with HQ filters? And If I did, how can I make my offline files same as good as Tidal does. Screenshots attached.
MQA has done different processing on the master and Roon unfolds it to 96/24 bit file to pass to HQP so you would expect a MQA file to sound different even if came from the same master as a CD. MQA is not really the same as a local ripped CD, try and compare a non-MQA version of the album from Tidal with your local files.
Yeah, you turned out to be right- different source material.
Seems to be 10% quality improvement from HQP gave my ears enough difference so now I can distinct it.
I found out that and found out as well that I don’t like SW’s version, cause the offline version I have is his from 2014 mix.
Turns out, Dave Bascombe did a better job, IMO.
