OS and hardware:
Roon Core - Windows 10 Professional - purpose built for Roon Core music server.
Asus Strix Z-370 I motherboard (ITX form factor)
Intel Core i-5 8500K CPU
16GB DDR 3600 RAM
3.5 TB M.2 NVRAM SSDs
All DAC’s, amps, etc. are directly connected to the core via USB
Software: Roon Core - 1.7 - build 537
2 ASUS RT-AX92U (AX6100s) routers in a mesh configuration (Asus “AIMesh”)
Server -> USB -> Chord Hugo 2 -> headphones (network is not involved)
Problem:
[Updated: new comments in bold italics]
Hi Folks,
Occurs with Hugo 2. Whenever Roon throws an error (e.g., “lost control of device”, “responding slowly”) the HUGO shuts off (all power). It repeated 4 cycles of the same behavior - I called it quits at that point and decided to seek help.
I do not know if the Hugo is the cause or the result of an issue - it has not occurred with other DAC/Amps (e.g., RME ADI-2 DAC FS). Server is stable and reliable and I have not noticed any errors recently except in this situation. I reinstalled the Hugo 2 drivers - the issue still occurred.
Additional info: I play mostly .dsf files, processing speeds are good - typically 6+x, all DAC/Amp devices are connected via USB to the core. Windows event log is not showing any errors, the drivers for both devices are current vendor provided ASIO drivers.
Is there some logging that I can turn on in Roon to assist in debugging the issue?
Thanks Steve
