I have built up a system need Hi Def indictor
You need to add an indicator or
better yet away to make HD def preferred
Currently I need to play a song before
knowing the playback quality.
At least Audirvana puts a little HD symbol.
Also, inadequate but better than nothing.
Enable them here in Roon Settings.
Where’s the HiRes label? I thought that was still a feature request
The OP said he finds HD symbol inadequate.
There is no Hires label but the sample rate / bit depth numbers can be displayed, so the actual information is there. It’s not necessary to „Currently I need to play a song before knowing the playback quality“
In addition, the rate/depth numbers are displayed on an individual album’s page, too. In addition, each version on the Versions tab shows the info, so it‘s easy to pick one as the Primary Version.
Yes, I have that, but would like the option of a HiRes badge on the artwork, just like MQA
Say
and
The MQA war is over, let’s move on.
Yes, but @David_Snyder had answered the OP. If you want the badge, it doesn’t exist.
One part of it seems to be that using the HiRes badge requires some kind of certification that is probably not free:
Japan Electronics and Information Technology Industries Association (JEITA) announced a specification and accompanying “Hi-Res AUDIO” logo for consumer audio products, administered by the Japan Audio Society (JAS).
This is probably why Audirvana uses the HD logo (which the OP doesn’t want either), so yeah this is still a feature suggestion. Why not, though I’d rather see the simple numbers and the version string rather than a meaningless logo
