I need help setting up Nucleus with Lumin T2
Do I just hook the T2 and the Nucleus up to the network using ethernet, or do I need to hook up the T2 to the Roon via USB? Does the Roon automatically find the T2 on the network? Finally, can I put my Nucleus on my rack with the rest of the hifi gear, or does it need to go into a different room? Thanks!
Yes.
No.
Either way works.
Thanks!!!
Bill
In Roon settings → Audio, please find Lumin T2 under Roon Ready section. Enable it, assign it a zone name. Play something and select this zone.
Thank you, Peter. I will try this as soon as my Roon arrives tomorrow.
Bill
This topic was automatically closed after 30 days. New replies are no longer allowed.
