Intel NUC 7i to Roon’s spec
Who is your internet service provider? ISR
Please list the make and model of your modem and router? Netgear ORBI router
Do you have any additional network hardware, like additional routers or managed switches? No, wired direct to router
Does your network have any VPNs, proxy servers, or enterprise-grade security? Nope
Mola Mola DAC with network card, wired via cat 6
Description of Issue -
What is the exact port forwarding error message you see in the Roon Settings → ARC tab?
“ipv4_connectivity”: {“status”:“NetworkError”,“status_code”:502,“error”:“error: Error: connect ECONNREFUSED 85.aaa.bbb.ccc:55000, response code: undefined, body: undefined”},
“external_ip”: {“actual_external_ip”:“85.aaa.bbb.ccc”,“actual_external_ipv6”:“null”,“router_external_ip”:“null”},
“upnp_autoconfig”: {“server_ip”:“192.168.1.1”,“found_upnp”:true,“error”:“<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/\” s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/\“><s:Body><s:Fault>s:ClientUPnPError<UPnPError xmlns="urn:schemas-upnp-org:control-1-0">501ActionFailed</s:Fault></s:Body></s:Envelope>”}
Hi
For months and months i have struggled with a double NAT problems. SOOOOO much time spent on this, and sooo much help from the people here.
Then, yesterday night, my ISP did some fiddling, and I notice that he is no longer using Cogent, but Orange. I check and the double NAT message seems to have gone. My tracer pings are looking different. I no longer see two changes of IP address. So my little hopes are up.
But of course port forwarding still does not work. My router does seem to have set up port 55000 to forward to the NUC hosting roon but I get a CONNREFUSED error.
I almost do not have the courage to start on this all over again. Can anyone suggest anything quick I could do?
Sorry if this is obvious, or in the FAQ, but I have been a bit ground down by the double NAT issue (which appeared to be inside Cogent somewhere).
