We’d love to help out. Could you please fill out the information in the template? That will allow us to make informed suggestions. Including a screenshot of Settings → Audio would help a lot too.
My Nucelus is plugged directly into my Orbi Wireless Router. I have had this set up for two years with no problem until I updated today to 1.8 (Build 880) Fall 2021… If I disable the Lumin and try to reenable it comes out grey again …like most of my devices… I rebooted my core and reinstalled the software to no avail
@wizardofoz’s suggestion might help. Would you might turning off, unplugging the audio endpoints for a few minutes, plugging them back in and turning them on.
I tried already of course. No change. Gotta love Roon - expensive , deeply flawed software and technical support is “did you try turning it off and on again?” Good grief.
Okay I turned off my Lumen device… unplugged it… it disappeared from Roon. Plugged it back in… it showed up …enabled it … Grey again… Something is different in this build and its more than one person
Yep. They have such great technical support - “Turn it off and back on again.” Unacceptable. And of course the average Roon user is sophisticated enough to have already tried this.
Same problem here since updating to 1.8, connected devices keep bugging out, every few seconds the list changes from some devices available to no connected devices screen to greyed out devices.
