I am running the Roon app on a Windows 10 64-bit notebook computer.
I am connecting to the internet using home wi-fi setup.
I am using a Linn Majik DSM for playing music.
very small
When I initially set up the Roon app to play music through my Linn Majik DSM, I selected it from the “roon enabled” zone. It worked fine. Then I experienced a brief utility power outage. Now Roon will not output to the DSM, and I cannot find it in the “roon enabled” zone, which has disappeared from the Settings → Audio screen.
Also ckeck the firewall exceptions for Roon and RAATServer still are working. Some recent Windows 10 and 11 updates are resetting these exceptions for some Roon users.
One thing to try before we dig too deep. Have you restarted both your core and your router? A power outage may mean an IP address is changed and such a change can cause Roon to have these issues.
If this doesn’t work I would like to see what your core is showing happening. In order to enable diagnostics mode, I’ll need the core turned on.
Wes,
I tried a number of things with my audio dealer Alon Moskovitch of Shelley’s Stereo. He is more technically savvy than I am. Nothing worked. Alon is on vacation this week.
I am still able to play music on my DSM using Linn Kazoo. So the problem is only with Roon, which cannot “see” my DSM.
It might be helpful if you could work on my computer. Please let me know if this is possible by sending me an email at [moderated]. Thanks.
Jim - not a good idea to post your email in a public forum. It’s likely to get harvested by spambots. You can let @Wes know your email by using the Private Message function of the forum. Thanks.
