- ROCK running on a NUC7i5DNH1E
- gateway: pfsense, running on a 4-interface device
- wan is on one interface
- wired “normal” is on a second interface, with subnet 192.168.1.0/24 (desktop is here)
- wireless is on a third interface, with subnet 192.168.2.0/24 (phone lives here)
- roon is on the fourth interface (it’s the only thing), with subnet 192.68.3.0/24, and a static ip (.2)
nothing particularly funky firewall-wise – port for ARC punched through, subnets are allowed to talk to each other.
- roon core is on the aforementioned NUC
- desktop is win11, just acting as a zone
- phone is Android (Pixel 7 Pro), running both ARC and Roon Remote
~400 tracks (pretty small, all things considered)
Roon Remote on my phone inconsistently fails to appear as an audio device (both under “select a zone” and under "settings → audio
Sometimes it just doesn’t show the phone itself as a playback option. Even restarting the app, clearing cache/storage, etc does not help. Even when the phone itself does not appear as an audio device, it can still control my desktop zone, browse the library, etc (that part is consistent)
When it works, there’s no noticeable lag in the phone appearing – sitting now at my desktop and closing an opening the app I can see the device appearing and disappearing as expected on my desktop.
For instance, I woke up this morning & it wasn’t appearing, I walked into the other room to start my day, did some stuff, then it appeared when i went to play some music. It worked before I took a nap, woke up to find it not working, did a buncha reading to try to figure things out and then it started working again, then stopped after i closed and re-opened it. It later started working again, and is working now.
It doesn’t seem like it’s a subnet issue, otherwise presumably my desktop would have the same issue, but the desktop seems to work fine (I can even see it disappear when my desktop sleeps, and then immediately reappear when it wakes up on my phone’s roon remote).
ARC playback continues to work consistently, even when the issue is occuring with Roon remote.
Do y’all have any tips on what network traffic to watch to debug this, or any ideas? the only thing i can think of off the top of my head seems like packet loss + udp issues, but that seems… questionable at best?
