Info about Nuc for Rock
Hi everyone I’m searching for a cheap Nuc where I can install Rock.
I’ve found the “ BEELINK MII-V” what do you think?
Specs:
M2 Mini PC Windows 10 64 Bit 4GB Ram DDR4 64GB M.2 SSD Intel Apollo Lake Celeron Processor J3355 CPU Dual HDMI Display 4K Desktop Mini Computer,Intel HD Graphics 500
Pre-installed windows 10 license system will be activated automatically when the internet is conected
※Essentials:
Product model: Mini PC M2
Dimension:12012024mm
Processor : Intel Apollo Lake Celeron Processor J3355 (2M Cache, 2.0GHz up to 2.5GHz)
Cache: 2 MB
※System Config:
OS: Support Windows 10 system 64 bit
Language : Multi -language
Graphics Processor : Intel HD Graphics 500
Installed RAM: LPDDR4 4GB
SSD Capcity: 64GB M.2 SSD
Ethernet: 1000Mbps LAN
WIFI: IEEE 802.11ac/b/g/n,2.4G+5.8G
Bluetooth: BT 4.0
Expand Memory: TF Card
※Performance:
2 Cores 2Threads
Burst Frequency: 2GHz up to 2.45GHz
Additional function:WOL & AUTO POWER ON
Internal Connector:SATA SSD 2242
Interface:
4USB3.0
1
DC Jack
1RJ45 1000M
2
HDMI 1.4b
1Audio Jack (HP&MIC)
1
SD cardreader
Adapter: 12V-1.5A 18W Certification ;
Input: 100-240V AC, 50/60Hz ,
Output: 12V 1.5A
※What you will get:
1* M2 Mini PC
1* UK Standard Power Adapter (12V 1.5A)
2* HDMI Cable
1* User Manual
1* User help card
1 * service card
1*Wall-Mounted bracket
Go with @Rugby’s advice and you can’t go wrong.
The BEELINK MII-V is not going to work for you as the processor has no grunt. To put it in context the recommended 8th Gen i3 NUC has a CPU benchmark score of 6118 whereas the BEELINK only 1155.
I bought a second hand NUC off eBay and it’s now in it’s second year and second roon upgrade and doing fine.
Apart from the fan there are no moving parts and it’s not exactly killing itself running roon.
