Inquiry about Roon Nucleus Rev A power supply specifications for LPS upgrade (ref#95SJHA)
· I am checking in regarding the correct power supply specifications for my Roon Nucleus (Rev A). I am planning to upgrade to LPS.
To ensure I am using the safest and most optimal setup, could you please confirm:
• The exact supported DC input voltage range (e.g., 12V–19V)
• The recommended amperage and wattage for a replacement power supply
· Haven't tried yet.
If you expect something like “better sound quality” from using some LPS, you may better stay in RL and spend your spare time and money on something more real :slightly_smiling_face:. Also, always keep in mind this device is a pretty standard mini PC, nothing else. You may create more problems than solving an imaginary one.
And for sure, replacing the PS against some LPS would void your warranty instantly, and very likely inhibit any type if good will actions - for actually nothing reasonable.
That’s a very honest advice :slightly_smiling_face:
Whilst I agree with your observations on the use of an LPS on a Nucleus, the quoted statement is unlikely to be relevant. I can’t see a Nucleus Rev A still being under warranty.
Hi @sivaramkumarsree,
Roon only officially recommends using the PSU that ships along with the unit.
If you’d like to make the switch, here are the specs:
19V / 3.42A / 65W
Center-Positive
2.5mm internal diameter
5.5mm external diameter
10 mm length
These will apply to all generations of Nucleus. See here:
