Ethernet to CX Ethernet to EX
Antipodes CX to EX via Etherent. then USB to Antipodes P2 and AES out to Dutch an Dutch 8C
After installing the convolution filter and doing some listening I wanted to go back to having the filter turned off. When I toggle the filter off in the DSP panel I get no audio.
I have not deleted the endpoint and re-added it yet.
Your results suggest that the Antipodes P2 is failing to change its bit-depth from 24bits back down to 16bits.
Enabling “Headroom Management” keeps the bit-depth at 24bits regardless of the status of the convolution filter. You could also try using the “Volume Leveling” feature found in the “Zone Settings” screen.
I recommend reaching out to the Antipodes support team with this report, they would be best positioned to determine what is causing this behavior with the P2. They have an inside track with our technical team if needed.
