Cat 6a around the house with Netgear switches
Allo Digione, connected via Ethernet to Roon Core to an Arcam irDAC II onto Adam F5 speakers, its my office set-up.
I have an intermittent issue when playing 96kHz content. When I try and play it, I most often, 99% of the time, get pops and crackles and the music jumps. This does not happen with content both above and below 96kHz (see below). However, occasionally, it will play with no issue. I did some testing and found the following;
Native
Music on NAS
Will play 48khz/24 bit
Will play 88khz/24bit
Plays 96khz/24 bit – but jumps, pops/crackles – happens 99% of the time
Will play 176khz/24 bit
Will play 192khz/24 bit
Music via Qobuz
Plays 96khz/24 bit but jumps, pops/crackles – happens 99% of the time
No 176khz/24 bit content to test
Upsampled by Roon
On Qobuz
Will play 44khz/16 bit upscampled to 176khz
Will play 88khz/24bit upsampled to 176khz
Will play 48khz/24 bit upscampled to 192khz
Will sometimes play 96khz upsampled to 192khz, sometimes pops crackles, sometimes silence.
Can anyone offer any advice? My workaround has been to downsample 96kHz stuff to 48kHz but I would like to fix if possible. Thanks.
I was going to suggest up-sampling some 44.1/44 content to 96, but I tried on my end and it’s automatically converted to 24bit from 16, so this won’t be very useful.
If you temporarily bypass the Allo Digione and connect the Arcam directly to the Core, do you experience the same behavior?
This is difficult, as the Core is in an upstairs cupboard and the DAC in the downstairs office. I wonder if I could bring the core down. I have a chromecast Audio kicking around somewhere, could I try that via its optical connection?
Of course! My main pc is connected to the same DAC, sorry, anyway…bit slow today.
Right, so I enabled an endpoint on the PC (Asio via optical) and my test album plays - Concrete and Glass by Nicolas Godin a 96khz 24bit album on Qobuz. It plays fine. I then switch over to the Digione, and I then tried the same album. For some reason I had the album set to upsample to 192khz, which played fine, I then set it to default, and the 96khz native version started jumping again. Then, I went back to the office PC endpoint (just changing inputs on the DAC for this) and played the same file again - fine, and then back again to the Digione again, and right now the album is playing at 96khz where previously it has jumped.
So the PC plays no problem, and the digione plays intemitantly. Its very odd. Any thoughts?
Can you please reproduce this behavior and note the exact local time + date + track you experience this behavior next on? I wonder if the logs indicate anything, once I have the timestamp + track, I can enable diagnostics mode and take a look for any additional clues.
I spoke to the technical team regarding this issue and the Roon logs show normal behavior when outputting 96kHz content, indicating that this issue is occurring after it has reached the endpoint. You may want to reach out to Allo and/or Arcam regarding this behavior to verify compatibility on 96kHz content for these devices.
