Asus router going to Cisco switch
dCS Rissini connected on ethernet
(All other devices connect without fail. Windows machines and Samsung tablet. it is only the A41 with the issue) I have changed my phone from an LG G5 to a Samsung A41. The LG would connect every time, but the A41 is very intermittent. If I kill the app on the A41 it will sometimes connect on restart of the Roon app, but not always. If I turn off WIFI on the A41 and then back on, it usually then connects. The issue has to be on the phone, but can’t find any setting to change to get consistent connection to Roon core. Any ideas? Thanks.
PS. Just tried on my wife’s Samsung A40 and that has the same issue, except that this won’t connect at all.
Hello @Andrew_Bennett, and thanks for your report! Next time you try to connect to your core, could you tap the “help” option and try entering the core’s IP address to see if you can make a connection? Also, is your switch managed?
I tried that, but didn’t work. Since posting this I have restarted the Roon process and it is now connecting on both phones. Coincidence? Don’t know. Let’s see how it goes… The switch is a managed switch. Cisco SG250.
