Is Roon Server running?
· "Waiting for your Roon Server"
What happens if you press the "Select a different Roon Server" button?
· I see my Roon Server, but I still can't connect.
When you try to connect, what screen do you see?
· I see the Server but the Connect button is grayed out
Please try to restart your Roon Server by closing the Roon app in the taskbar or rebooting your Roon Server machine.
· *Roon Optimized Core Kit* (ROCK)
· *Mesh networks*
You mentioned a mesh network in your setup. Certain common mesh networks might require slight reconfiguration to support Roon.
· Orbi
Click below for next steps with an Orbi mesh network.
· I still need help.
Out of sudden, one of int amp lost commection only with Roon(NAD C399. Only Roon connection is gone. I still can use machine with BluOS or Tidal Connect)) and only my Iphone doesnot connect to Roon. (Means my other Roon Remote decices are fine such as Ipad, Macbook and Windows Surface)
Funny thing with my iphone is that I cannot conmect to Roon with Roon remote app but I still can connect to Roon with Roon Arc app.
Ring Orbi RBR 40 with 4 satellites
