Intermittent connectivity issues with Roon on PC every two weeks (ref#G3DE59)
Is Roon Server running?
· "Waiting for your Roon Server"
What happens if you press the "Select a different Roon Server" button?
· I don't see Roon Server.
Please try to restart your Roon Server by closing the Roon app in the taskbar or rebooting your Roon Server machine.
· *Nucleus*
I tried the nucleus, took it out, using PC same issue happens every two weeks
direct from router
Hello @Dean_Patriquin ,
Can you please provide some more information regarding your Roon setup? Has Roon been installed on your PC and it’s been a while since you last used it? If you navigate to Roon Settings → About, do you notice any updates pending? We’ve activated diagnostics mode for your account, can you please use the Roon app on your PC for at least a few minutes and let us know here once you’ve done so?
