Acer Aspire A515-52G
Inter Core i5-8265U @1.60Ghz
8GB RAM
Windows 10 Home
Netgear Orbi RBR50
TP-LINK TL-SG105 network switch between Orbi satellite and Roon Core.
Roon core connected via ethernet connection
Naim Uniti Atom HE connect via ethernet. One connected to the TP-LINK TL-SG105 network switch on the same satellite the Roon Core is connected to and the other via ethernet to a different Netgear Orbi satellite.
Around 10000 tracks
At random moments listening to Roon causes the network on my Netgear Orbi to shut down temporarily. This only happens when using Roon and no other forms of streaming or network access. It seems to have gotten progressively worst with Roon updates.
When this occurs all devices connected to the network (especially those connected with ethernet cables) temporarily loses connection to my home network.
This causes playback on the Uniti Atom HE to stop immediately and user interaction is required to restart the playback once the network has been re-established.
When this occurs the Roon core also loses all internet connection as well.
I have tried everything I can think of to solve this. Moving the satellites, trying wifi connection on the Unit Atom instead and also installed a network switch between the Orbi and the Roon Core as suggested in a post I found on this forum. IGMP proxying is also enabled.
It appears since the installation of the network switch and attaching one Uniti Atom HE to the switch as well, the dropouts on THAT Atom has stopped.
The other Atom, connected to a different satellite, is suffering more and more dropouts as Roon is updated. At the moment it is sometimes unusable, dropping out multiple times in one track or album.
What is strange is that sometimes days can pass with no dropouts and then suddenly it is unusable for a few hours.
Native streaming on the Uniti Atom HE does not suffer from the same problem and is perfectly stable.
I have therefore concluded that this seems to be related to Roon communication on the Netgear Orbi specifically.
I cannot see anything in the admin logs of the Netgear Orbi that would suggest the cause of this issue.
Can you perhaps help me find the root cause of this issue? I am at the point of cancelling my Roon subscription due to being unable to use it as intended.
