· Windows
· Windows
· I can't log into TIDAL, KKBox or nugs
Have you been redirected to the Tidal/KKBOX/nugs login page in your browser?
· Yes
Content / Popup Blockers
Different device
Record the timestamp
· now it is connected but playlists missing
i am able to log in to tidal, after several attempts, but keep getting disconnected. Also when connected dont see all my playlists.
Thanks for posting. Automatic logs have reached our servers and we’ve been able to pinpoint the errors you describe.
These upstream failures aren’t limited to Tidal. Roon also can’t reliably reach upstream metadata and cloud account servers and RoonServer is logging network timeouts with nearly every request. Tidal login failure is a symptom of that, which is also why browsing comes up empty and playback drops.
Please work through the following in order.
On the same computer that runs Roon Server, open a web browser and load the Roon account page. Report back whether it works. Try the same with the Tidal web player.
Confirm whether you are running a VPN on this computer. Do you have a PiHole or any other network-wide security installed?
If you do have a VPN, turn it off completely and restart Roon Server, then check whether Tidal logs in.
Let us know if this helps. We will watch for your response and proceed from there. If you require additional time on your Roon trial to make up for lost troubleshooting time, we will, of course, offer an extension.
