· MacOS
· iOS
· I can't log into TIDAL, KKBox or nugs
Have you been redirected to the Tidal/KKBOX/nugs login page in your browser?
· Yes
Content / Popup Blockers
Different device
· I am able to switch to the diffrent device
Record the timestamp
· Today during the day between 13:00 to 17:00 EU timezone
I have signing in issue with Tidal, from time to time, I discovered that the problem exists mainly when the MacMini is connected through the ethernet cable, when the mac has wifi connection on the issue does not exist. I already complaint to roon a month ago and solved it by using wifi because I thought that it might be some router problem. But since then I did all the possible changes and tests. I even reinstalling the the roon of different MacMini, so today the roon server runs on different hardware, but all stays the same.
I wondering whether this roon issue or Tidal issue, maybe some of the networks doesn't like the stable IP address, with ethernet connection it always the same.
Please advise.
Router with connected mesh access points TpLink, with connected roon server through ethernet cable.
