The OS, applications and all my CD rips are stored on a Kingston NV2 PCIe 4.0 NVMe 2TB SSD
RAM memoy in use is 1x Kingston ValueRAM 8GB at 3200MHz
Netgate 6100 pfSense router
1x Ubiquiti UniFi 6 Pro Wi-Fi
3x Sonos One SL
17883
I basically only listen to albums and I play them start to finnish. For some reason Roon sometimes skips a song or only plays the first split second and then moves on to the next song. Sometimes it even skips two or the interface is out of sync with the actual playback.
It is really frustrating, also because it messes up the number of plays of a song.
The latest Roon version did not resolve the problem.
I just realized I think I’ve been seeing the issue with other audio devices as well I’m afraid.
A MacBook Pro with heaphones had the same issue if I recall correctly.
Everthing is wireless. The only LAN cable in my tiny appartment is the one from the router to the wireless access point. Can’t say I have wireless connectivity issues. The server also seems pretty much idle all the time.
-update-
It’s only been happening when listening via Sonos.
Thank you for your continued patience while we work through each thread.
If at all possible, are you able to test hardwiring your core / sonos endpoints?
I’d be curious to see your network bandwidth options from your router. Are you able to select 2.4Ghz or 5Ghz? Can you assign specific devices to specific bandwidths? If yes, you may know where I’m heading with this.
I would make sure your core and sonos endpoints are on the same bandwidth - ideally 5ghz, but it would be good to test both (again, if this is an option.)
Outside of this, could you please recreate the issue and share the specific date and time back here? That will help us pin down what might be going on. I’ll enable diagnostics on your account so we can take a closer look.
The #1 suggestion that people facing this type of issue get is to wire their core. If it were me, I’d purchase a $20 dumb GB switch and be done with that.
There are a number of threads on this, but it’s a strong Roon suggestion to wire your core at a minimum. Id certainly wire one of your Sonos endpoints as well. I realize it’s not what you want to hear, but Roon is very very demanding network wise. Good luck.
