Windows server 2019, AMD ryzen 7 1800x, build 1.7 555
Everything connects to an Asus AC1900 wi fi modem, core remotes etc. Server 19 machine has rosewell RNX1900 wifi card
USB Dac (T+A dac8DSD)
Had to do clean install of windows server 19 and roon core. Now remotes will not connect to roonserver on core machine. I keep getting connection failed message. As work around I added Roon to my server 19 core machine to use as a remote. On login screen I selected restore from a backup I searched where my backups were and roon finds only 3 backups (June 13, 2019, June 17, 2019 and Feb 12, 2020, I back up every 4 days) Before the clean install I checked my backups and roon indicated last successful back up was June 1, 2020. I then closed the roon login screen since I could not find the most current backup (june 1), without logging into roonserver to see if that worked.
I have 2 issues- 1) remotes (IPad 10") will not connect to roonserver on core machine. and Yes I added Roonserver.exe and raatserver.exe to exceptions list in firewall. and 2) where is my most current backup? I backup to a 16gb USB stick and before clean install roon indicated last successful backup was June 1.
Before this mess I used the same PC, wifi gear and same server 19 OS with multiple remotes and had zero issues. (except for the jumping queue).
