Whenever I try to access roon from my iPad it doesn’t find the audio devices.I have to go to the core connect one of the devices and only than they appear again on my iPad. The core is 2.0 and the iPad updated
@Shlomo_Drechsler, I have moved your post to the #support category. Please complete the following support template. Thanks.
<!-- Include your operating system and machine info (Model, CPU, RAM) -‐>
<!-- Write below this line -‐>
<!-- Your network gear (model of routers/switches) and if on WiFi/Ethernet, are you using YPN -‐>
<!-- Specify what devices you’re using and their connection types, like USB/HDMI/Chromecast, etc.) -‐>
<!-- Tell us how large your music library is, eg. “30,000 tracks” -‐>
<!-- Tell us about the problem you’re having in as much detail as possible. Screenshots are always appreciated! -‐>
Hey @Shlomo_Drechsler,
Ben here with the support team following up. After reviewing your account, it looks like you’ve been able to successfully sync your ropieee audio devices to your iPad.
Please let me know if you’re still having issues here
