iPad Pro has been working as an endpoint perfectly until current release 1.7(521).
Now although a item indicates it is playing the volume control is set to zero, when moving the volume slider it reverts back to zero as my finger is removed from the screen. With nothing playing the volume control slider also reverts to zero.
I haVe deleted and reinstalled the Roon Remote app (before & after restart) Restarted Roon core & machine (Win10 pro). Other networked devices appear to work correctly.
The problem persists, any help would be welcome.
ps. I just remembered there’s been a recent iPadOS update, I have also reported to Apple.
Tidal & other apps function correctly. After the initial screen recording Roon changed from volume zero to 16 But displays similar issues, both records are attached.
Hi Dylan, I think my bug report To Apple four days ago has got a result. There was, unusually, another iPadOS update this morning seven days after the previous one. A quick test shows that the volume & control bug has been fixed, everything now seems to work correctly.
